Sponsored by: CARiD
Freelander starting after a jump
Old Jan 15, 2007 | 05:09 PM
STACKER's Avatar
4th Gear
Default Freelander starting after a jump
Hi new member Rover owner past 10 years. due to gas, my disco had to go, I decided on a two door freelander and love the vehicle. Only problem is I jumped my sons car and since then I turn the key nothing from the starter everything else on , I hold the key for anywhere from 0-6 muniutes and she fires up (strong). replaced all the yellow relays no help. looked all over the web found one listingabout the jumpimg and a srs problemcode scrambled or something. This is a common problem with the starters just no answers lets find one.. thanks Pat
Old Jan 15, 2007 | 07:41 PM
Default RE: Freelander starting after a jump
Pat, I am confused, are you saying your starter won't turn over, not clicking or anything and then it will start with a lot of persistance?
Mike
Old Jan 16, 2007 | 11:45 AM
STACKER's Avatar
4th Gear
Yes that is exactly it ten minutes of holding the key all the way in the start position then she just starts out of the blue. no other iyems on when the key is turned all the way. thanks
Old Jan 16, 2007 | 03:20 PM
05LandRover's Avatar
I've jumped several GMs with mine and no problems
Old Jan 17, 2007 | 06:04 PM
STACKER's Avatar
4th Gear
Hi just left the dealership I guess it had nothing to do with the jump they replaced my ignition switch at a real decent price fired right up. They knew what it was immeadiately a piece was broken at the rear of the swith . well I love my rover again thanks for the attempted help pat
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
loomy123
Jan 4, 2014 09:09 PM
fingerprint gal
Nov 11, 2012 07:56 PM
bowser881
Dec 17, 2009 01:19 PM
cobralootman
Dec 5, 2006 02:38 AM
