Sponsored by: CARiD
Front Cover Gasket Set Help
Old Jan 5, 2011 | 02:16 PM
DiscoRover007's Avatar
Default Front Cover Gasket Set Help
Hey guys, this is my brothers account, but I am fixing his car... So, I need to find (preferably an aftermarket) front gasket set. So far I gather that I need the timing cover gasket, oil pan gasket, water pump gasket and front main seal. Is there anything else I would need? Also if you guys know where are some good places I could get this stuff, that would be a BIG help.
on a side note - I have a concern about his oil pump, I have read about oil pump failures on this cars. His is a 03 and 130XXX on it. I heard that if it fails it fails early on. Should I replace it?
Thanks guys!
Old Jan 10, 2011 | 03:44 PM
D2's Avatar
D2
I like Rovers North, if they don't have it Atlantic British usually does. At that mileage I would replace the thermostat and water pump if it has not been done already.
Get the ford fan clutch tool from Advancerd auto.
I am told get the OEM front seal, cheapos don't seal well.
As far as the oil pump I would find out for sure if your's / his is in the recall range first. Identified by the VIN no., and on the dealers/ manufactures recall lists.
Do a search in the forums here for the oil pump issue and the rest of the parts you are replacing you should get some good advise. Also I believe there is a "sticky" or "walk through" on replacing the front cover and associated gaskets.
bagocheetohs
Aug 11, 2015 06:13 PM
outdoor7or24
Dec 22, 2014 09:31 PM
diego rover
Nov 7, 2007 04:22 PM
