Sponsored by: CARiD
Fuel pump?
Old Aug 30, 2010 | 07:02 AM
antichrist's Avatar
Reportedly the ones from NAPA and Advance Auto work.
NAPA PN - ECHCSS928
Advance Auto - CSS1050
Old Aug 30, 2010 | 03:40 PM
disco chelsea's Avatar
O.K. Guys I ordered the crank sensor today will be here wed., After I ordered it I then read up on it, And learned that it has to do with when the car fires. Now this concerns me because as I said in a previous thread the fuel pump does not always pump gas when I disconnect the line from the pump and try to turn it over, The car is getting fire. to late now might as well replace it already removed old and ordered new. will I have to reprogram it when I install the new one. maybe I just don't understand. I can do the work, like I said I already removed old crank sensor, and accessed the fuel pump. Just need help understanding. Thanks.
Old Aug 31, 2010 | 06:51 PM
Thanks Disco Mike, and Lordmorpheus. I just installed crank sensor today, would be an easy fix if you could get to it, Took awhile but I got it. Started it up let it run for 20 min. then went for a ride came home turned it off and on a few times and then let it run for 20 more min., all seems fine. fuel pump going back tomorrow. Thanks again.
Old Aug 31, 2010 | 08:07 PM
lordmorpheus's Avatar
Great to hear, and thanks for reporting back!
Travelor
Sep 24, 2015 06:11 PM
JumPeR04
Apr 7, 2011 09:52 PM
leadfoot
Sep 13, 2009 09:51 AM
discoken
Nov 4, 2008 12:39 AM
