Sponsored by: CARiD
fuel reset button on 98 disco???
Old Jul 14, 2009 | 12:22 PM
1000$ rover's Avatar
Default fuel reset button on 98 disco???
I have a 98 disco i just bought and it runs only if you spray gas into the intake. It s probably the fuel pump and/or the fuel filter. I was wandering if there is a fuel system reset button that may be tripped somewhere. Anybody know??
Old Jul 14, 2009 | 12:27 PM
Look on the passenger side of the firewall, do you see a black switch, not sure if you have one, if there push the top of it and see if it makes a difference.
If not check your fuse, possibly replace your fuel pump relay and for sure change your filter.
If still not working, then how mechanical are you?
Old Jul 14, 2009 | 12:34 PM
ok found the switch and its not tripped...... next where is the fuel filter? Pretty mechanically inclined worked in fathers garage as teenager..... never owned a rover before but always had jeeps and other 4wds ps fuse is good
Old Jul 14, 2009 | 01:51 PM
antichrist's Avatar
Fuel filter is in the right rear wheel arch.
You can verify if it's your pump or not by bypassing all the electrics and running a fused 15amp supply to the fuel pump and see if you can get it to run.
chakadog
Jan 9, 2021 06:53 PM
spudley
Sep 29, 2009 08:46 AM
discodefender
Feb 4, 2009 08:01 PM
Rover5150
Feb 3, 2008 12:33 PM
ericlt
Apr 28, 2006 07:01 PM
