Sponsored by: CARiD
Is this a fusible link?!?
Old Oct 30, 2015 | 06:13 PM
Roverfanatic's Avatar
Default Is this a fusible link?!?
As the title says...is this a fusible link and should it have continuity from one pin to another? It was attached with factory tape to the Stop lamp switch suppressor....
Thanks,
Tex
Old Oct 31, 2015 | 06:14 AM
ihscouts's Avatar
Fusible links look like thick wire. That's an electrical suppressor which is a capacitor and you wouldn't get continuity on a capacitor. I noticed in the Rave that the wires to/from the stop lamp switch suppressor are red, sure looks like a spare.
Old Oct 31, 2015 | 10:41 AM
Okay,
Thanks iscouts...my search continues. The driver side rear tail lights are not working. Good ground on continuity check but no power....
Old Oct 31, 2015 | 04:44 PM
ihscouts's Avatar
I was going over the wiring for the rear lamps, holy cow there's allot of splices. If there's no power on the green/purple wire I would check further upstream. Seems most of the splices are either under the steering wheel or near the blower.
Old Oct 31, 2015 | 05:51 PM
Yea, it's pretty much over my head as far as following it with the rave. I followed the entire harness back to under the steering wheel and have not found the problem yet. It's very hard after it comes down the side post as it reintegrates with the main bundle again.
Old Oct 31, 2015 | 05:52 PM
No the "entire" harness....... the bundle from the back specific to the lights...
Old Oct 31, 2015 | 06:14 PM
ihscouts's Avatar
Somebody had the exact same problem here, changed the brake light switch.
Have you checked your cruise control switch and system?
Old Oct 31, 2015 | 10:39 PM
I checked the switch, it's good and I by-passed the switch and still no joy. I have not checked the cruise control switch. Will do that...
Old Nov 1, 2015 | 11:36 AM
Update...after re-installing the brake switch...the brake lights now work but no running lights. I won't have time to troubleshoot till later today....
cfd01
Dec 14, 2012 02:30 PM
Oscar G
Aug 20, 2007 05:18 PM
WOZ
May 24, 2007 02:36 AM
trev
Mar 11, 2007 08:29 PM
jamie
Nov 28, 2006 06:44 AM
