Sponsored by: CARiD
Help with 2007 Range Rover HSE.
Old 01-11-2021 | 08:07 AM
Lee Smith's Avatar
Default Help with 2007 Range Rover HSE.
I changed the water pump, serpentine belt and coolant. I bled the air out of the coolant system. My problem or problems is as follows. The engine won’t crank properly. It sticks, meaning the engine turns over but won’t crank. The key stays in the cranking position. When it finally cranks, the rpms are at 1000 at an idle speed. When I drive it, it seems to be stuck in a gear, I’m tinkling third. It won’t shift either. I only test drove it done my street. It’s parked again. I have two warning lights on. One is the triangle with the arrow around it. I believe that is the brake? I also have one with the triangle and the exclamation point in it. I’m lost at what to do. Is there a fuse? A sensor? Any and all help would be appreciated. Thank you!
Murph9265
12-25-2015 10:01 PM
kleener
07-12-2013 08:06 AM
surfrider
09-17-2012 07:10 AM
Jason428sc
07-21-2011 08:37 AM
philsk8ts
12-03-2008 06:15 PM
Quick Reply: Help with 2007 Range Rover HSE.
