Sponsored by: CARiD
Help with codes p0130/p0171
Old Aug 5, 2011 | 04:03 PM
disco chelsea's Avatar
Default Help with codes p0130/p0171
Started running rough, then engine light came on throwing codes p0130 and p0171. o2sensor? which one, where is it, and what tools do I need to change it. 03 disco. need to know what to ask for when I order.
Thanks.
Old Aug 5, 2011 | 06:30 PM
95% of all O2 codes on a Disco are because you need a good old fashioned tune up, that means spark plugs and spark plug wires.
Not store brand wires either, Magnecor, STI or Kingsbourne wires only.
Any spark plug you want, the truck came with cheap Champion cooper spark plugs from the factory.
Old Aug 5, 2011 | 07:28 PM
after erasing codes the engine light came back on with yet another code . this time i'm getting p0134 02s CKT no activity detected. when I research it I get no difference between p0130 and p0134. I have a actron autoscanner plus. not sure what to look for with the other features.
Old Aug 5, 2011 | 08:04 PM
lordmorpheus's Avatar
Check the sensor plug for oil contamination. If the connection has been in the path of an oil leak, the oil might be causing enough resistance for that sensor not to be working properly.
Old Aug 5, 2011 | 08:20 PM
Sounds like a good start, if knew what,where, and how. How about all the codes. p0130, p0171 at the same time, and then p0134 after reset
Old Aug 5, 2011 | 08:55 PM
Bank 1 sensor 1. That is going to be the left hand sensor in front of the catalytic converter. Follow the exhaust pipe coming off the left side of the engine (driver's side in the States). Just before it disappears under the firewall, you should see the sensor. See if the sensor wiring connector is covered in oil, disconnect it, and check for the same inside the connector. If oil is found, clean with brake cleaner, apply dielectric grease, reconnect, clear codes, and see if they come back. If the connector is clean, it may be a bad sensor, or a problem with the wiring to the ECM.
I would check the oxygen sensor first, and see if once repaired, the O2 sensor fixes the P0171 lean condition.
Old Aug 5, 2011 | 10:37 PM
That answers a lot of my questions. Truck only has 53,000 mi. on it so I hope that's it. Now if it is oil leaking that presents a whole new problem. Can I drive it till I get it fixed. Thanks.
Old Aug 5, 2011 | 11:03 PM
IF the sensor connector is oil saturated, it is probably coming from the valve cover gasket on that side. This is a common problem on these vehicles. The valve cover bolts get loose and need to be tightened to specs at every oil change (at least the two outside bolts that are downhill and easy to get to).
The O2 sensors before the converters determine fuel input to the engine. Most likely, until the problem is fixed, your fuel economy will lessen, as the computer doesn't know when to lessen the fuel input.
Old Aug 6, 2011 | 03:13 PM
orange plug end is covered in oil. I can reach it from the underside of truck, cant seam to unplug it. any tips? Thanks.
Old Aug 6, 2011 | 04:19 PM
There is a tab on the connector that needs to be pressed for it to come apart. If the oil is saturating the connector so you can't see what is what, get some brake cleaner, or purple cleaner to clean the oil off so you can find the tab. Then, just press the tab with one finger, and pull the two halves of the connector apart with both hands.
