Help with fault codes
I purchased an iLAND device form Atlantic British. Pulled the report and have lots of codes. Where do I start and how do I decipher the codes. Please see the attached report. Main issue is suspension fault. I’m guessing maybe it’s the compressor. Thanks in advance for your help.
Cleared the codes and the suspension fault pops back up as well as a few others. The main issue is the suspension will not air up. I'm thinking the compressor is bad but is there a resource that shows the fault codes and what they mean? Given the cost of the compressor, I'm hoping to verify this is causing the suspension fault on the device and dashboard.
