Sponsored by: CARiD
fault codes
Old May 14, 2010 | 02:34 AM
billautobill's Avatar
3rd Gear
Default fault codes
can any give me the meaning of fault codes p3030/p3046/p3014 have fitted egr bypass kit also air mass meter cleared codes but keep showing thanks for any help bill
Old May 14, 2010 | 06:01 AM
antichrist's Avatar
http://www.obd-codes.com/trouble_codes/landrover/
Old May 14, 2010 | 09:15 AM
Give us more information, year, model and mileage and why did you by-pass the EGR???
Old May 15, 2010 | 05:06 AM
3rd Gear
Unhappy code fault
egr valve was reading stuck open it.s done 80.000 miles ser on regular basis no problems before this thanks for any help you maybe able provide disco mike
Old May 17, 2010 | 03:30 AM
3rd Gear
Thumbs up faults
Originally Posted by johncarry
Ask the technician that installed the new O2 sensor why you still have an O2 sensor error code. It's probable that the O2 sensor wasn't bad unless the code was for a burned out O2 heater element.
i fitted it myself the air mass meter was blown on element also found a blown fuse in engine bay compatment which i think had something to do with it also oil is getting back down to ecu so thinking about changeing injector harness just thiking now it could be causeing some of the problems never had any before this pain in the rear end thanks very much for your input john if can think of anything else would be helpfull bill
06Range
May 8, 2013 09:01 PM
04SSHD
Apr 11, 2012 06:20 PM
BajaXJ92
Dec 3, 2009 07:43 PM
