Sponsored by: CARiD
Help on fuel pump replacement
Old Apr 26, 2011 | 02:19 PM
andrewed's Avatar
4th Gear
Default Help on fuel pump replacement
Hello,
I have a 2002 Disco II that needs to have the fuel pump replaced. Does anyone know a good how to guide on the internet that I could utilize? Also, from what I've read so far, it appears the pump can be accessed through a panel in the cargo area? Is this correct?
Thanks for any help.
Old Apr 26, 2011 | 07:25 PM
Discovery I Fuel Pump Removal / Fix - Land Rover Forums - Land Rover Enthusiast Forum
Land Rover Fuel System Parts | Fuel Pump Discovery 2
That write up is in the DI section but it also applies to the DII.
Old Apr 27, 2011 | 08:47 AM
How do you know your pump needs to be replaced, what is your truck doing wrong, is your check engine light on?
Old Apr 27, 2011 | 10:25 AM
andrewed's Avatar
4th Gear
Mike,
The issue is it starts fine cold and I'll drive it a while get back in and it will not start. It just keeps turning over. If I let it cool down it will start. Also at times it will just stop running. I drive down the road and it will cut off. No check engine light.
Any ideas?
Thanks,
Old Apr 27, 2011 | 10:26 AM
andrewed's Avatar
4th Gear
Mike,
Any ideas?
Thanks,
Old Apr 27, 2011 | 10:59 AM
That is a typical Rover crank sensor failing. Look at the money you just saved!!!
Old Apr 27, 2011 | 11:38 AM
andrewed's Avatar
4th Gear
Thanks Mike. And links on how thats installed?
Travelor
Sep 24, 2015 06:11 PM
gman21
Jan 2, 2013 02:03 PM
gulfcoastgorilla
Apr 15, 2012 05:30 PM
JumPeR04
Apr 7, 2011 09:52 PM
03RRDude
Oct 26, 2009 07:18 PM
