HELP - Not sure if my mechanic is scamming me!
1st your Tucson guy should have replaced all 4 with new bosch sensors. (the usual "electrical issue" with o2, is not having proper connections at their plug)
2nd your canucks should have also.
they really are guessing if they are using old junk that is lying around.
you are back where you started with what will surely be lighter pockets.
4 bosch sensors. o2 wrench. pb blaster. a couple hours/2-4 depending. dielectric grease.
just my 2
just my 2
Earl
How about giving us the exact codes that are being thrown, this may go a long way toward pin pointing the source of the problem.... after all that's what an OBDII equipped vehicle is supposed to do, point the mechanic in the right direction without having to take shots in the dark.
At this stage, they know I'm unhappy at their approach, price, and diagnostic success, and are pushing back.. I don't think I'm about to get the full readout... although when I pay them their ransom, I assume it's reasonable to ask.
Thanks for the response.
Yeah but are they "o2 not working" or "the exhaust hitting the o2 isnt clean enough" codes?
At any rate...
- I used NGK o2s when I did the upstreams on my 04. Theyve been fine for over 20k miles now.
- $1500 to replace the 4 o2 sensors on a discovery (i.e. not that hard) means you are bending over and spreading.
At any rate...
BUT yes, an hour of labor for each and $245 (I believe) for each for originals ($1400!) was what made me hesitate. I actually asked if he could source aftermarket units (which I've come to see are much cheaper) - but instead they 'swapped' existing units with supposedly working ones, and when the codes didn't clear, they put back the originals that were there. $500 gone. Now that I've done some poking around, and given that the beast is 10+ years old with 100+ thousand miles on it, I certainly would have spent $750 to have the four new (aftermarket) units in there, rather than $500 for nothing, but that wasn't offered as an option.
I'm going out to buy some Preparation H
"BUT, The owner of this place tells me he's been doing this for decades, and that's just the way it goes with troubleshooting 'old' rovers, and if they can't fix it nobody can"
RUUUUUUUUUN!!!
And/ Or push this thing to Buffalo, NY.
Athol Motor Car 184 Reading Avenue, Buffalo, NY 14220
(716) 824-2276 Keith and Jeff can set this right.
RUUUUUUUUUN!!!
The irony about your Buffalo friends is that the beast had to sit in a parking lot in Buffalo for a week on the way back because I had to get 'export permission' from the US Customs department. Should have posted to this forum then. (smacking my forehead!).
The poor disco is now caught in 'no mans land' - it's been legally exported from the U.S. but I can't get it registered in Canada. And yet if I try to drive it across the border to Buffalo with Arizona plates on it (and my Canadian Passport) it will set off red flags with border patrol.
Yup. I'm snookered.
Not giving up yet tho!
Thanks for the insight.
E
Hah, my first thought too
I was just going to pull the bulb
But the tests here go by OBD2, and if there are codes that would put that light on, ...FAIL.
$1000 in labor for throwing a few used parts at it is pretty ridiculous. Like the others have said, it would help to know exactly what codes you have but for a shop that specializes in Rovers they seem fairly incompetent. Getting beat up on hard to diagnose problems is part of the business sometimes, you can't expect the customer to pay way above and beyond normal diagnosis time just because you're not good at what you're doing. Especially when they still haven't figured it out.
I would take it elsewhere.
My conundrum ( or perhaps Canuckdrum?
is that if I go somewhere else, they'll want to 'pull the codes', and want to replace the O2 sensors, and likely disregard what the current guys did, in which case, the first $1000 is completely down the drain, and, if this problem is truly the kind of gremlin that just isn't easy to track down and does require trial and error, then I'm about to spend it again with a new guy.That's why I reached out to you folks with some objective experience... to see if I'm being unrealistic, or if they are.
I'm assuming that given the choice between a) paying the grand, and letting these same guys now pull my catalytic converters on the 'chance' that they're the problem ($800 MINIMUM they say) and b) just starting fresh with someone new, and walking away from the grand, you'd lean toward b, based on what you've read?
Thanks for your insight regardless..
http://www.amazon.com/gp/aw/d/B0018R5SOW/ref=mp_s_a_1_1?qid=1418481731&sr=8-1&pi=AC_SX200_QL40
Just over $50 for the fronts. Orange connector model is on the front and grey connector on the back.
Your situation is not uncommon and those 02 codes can be a nightmare.
Let me add:
- do whatever it takes to get the car out of there at the lowest price(try the poor me I can't afford that price route, catch more flys with honey approach)
- nicely ask for the old parts back(ECU and O2 sensors, they should not need them because they were obviously bad, right?)
- buy4 new sensors, change them yourself. Use electrical connector cleaner on the connections before connecting, dielectric grease after to seal the connectors.
- buy an affordable OBD2 scanner.
- start to become mechanical real quick. If you love your rover, you're going to have to work on it yourself.
- possibly look into a parts truck, or better yet but an 04' with good paint that can pass smog and turn the 03' into your auto parts store/ tester.
Goodluck
Let me add:
Goodluck
I don't think I have the time or money to love the Rover THAT much
Remember, I already have a SAAB
E
Diagnosis by definition means "identification of a problem". Throwing parts at a situation is not a professional means of diagnosis. That's called guessing. If these guys were professionals they would identify the problem, sort the data, and come to a conclusion. Not just stab old parts laying around hoping it fixes tell problem.
This goes for the AZ guy too. All four sensors should have been replaced (assuming your codes are really for 02 sensors). To just say "oh its probably in the wiring" shows me the mechanic has no idea of the the problem.
There is going to have to be a reasonable charge for diag time. 1000 dollars is insane. BUT did you specify that the bill should not exceed a certain amount? That is also your responsibility. Any good shop would call you once the cost started to skyrocket. But you have to always be a smart cautious customer. So laying down a set amount saves you of a problem like this. Also did they have a signed work order by you agreeing to this amount? Or one that was vague agreement?
I agree about the nature of diagnosis. Just wanted some validation from you guys.
To be fair to my AZ guy, it's my fault he didn't replace them all. I was being cheap.
Re the Toronto guys, I was surprised when they told me I was into $500 in labor to swap the sensors, but not improve or discover anything except that it wasn't the problem.
When they told me they were pretty sure it was the computer, but to pull one out of their parts disco, reprogram it, and install it in mine would cost $500 in time, I didn't see much alternative.
What I didn't expect is that after doing both those things, they still don't know what's wrong, I have no 'improvement' by way of at least having newer, working parts, and that they would ask for hundreds more just to do the next EXPERIMENT.
No, I didn't sign anything, and no they didn't give me a written estimate. Frankly, I don't know what happens if I go try to get my vehicle back... Can they hold it hostage? I presume if I were to take it back they'd 'sue' me for what they considered the damages... but I've never been in a situation like this before.
Usually, I'm not a sucker or uninformed. This just caught me looking like that
