Sponsored by: CARiD
help!!!!!!! please
Old Jan 1, 2013 | 02:14 PM
dobe1canobe's Avatar
Default help!!!!!!! please
i have a 2000 disco 2. 90k new plugs (cheap ngks) wires,crank position sensor,mass air flow sensor. im still getting a rough idle after warmed up and after about 30mph on acceleration im getting a vibration. loss of power and mpg. any advice?
Old Jan 1, 2013 | 02:16 PM
problem slowly has gotten worse since tune up about 3-4 months ago?
Old Jan 1, 2013 | 02:32 PM
What fault code numbers do you have?
Old Jan 1, 2013 | 02:47 PM
vaccume leak,system lean and o2 sensor. is it possible that the cheap plugs i used could be causing this? i have also to the best of my ability checked all vaccume lines but i didnt find any cracks or anything.?
Old Jan 1, 2013 | 03:35 PM
Its not the plugs, I usually run $.99 plugs, cheap copper plugs are what came in your truck.
Did you replace the plug wires too?
Are you loosing any coolant?
Old Jan 1, 2013 | 03:38 PM
yes i did the wires also. no coolant loss.
Old Jan 1, 2013 | 05:22 PM
Was it doing this before the tune up?
Old Jan 1, 2013 | 06:00 PM
ok i just got back from auto parts store heres the codes that are coming up p0139,p0130,p0171 and p0455 thank-you
Old Jan 1, 2013 | 06:01 PM
Old Jan 1, 2013 | 06:02 PM
no but it did have a little bit of a rough idle.
