Sponsored by: CARiD
Hey Gearheads!
Old May 31, 2010 | 09:10 AM
RoverRookie's Avatar
Default Hey Gearheads!
Just throwing this out there...going to be replacing a few hoses soon and was curious which clamp everyone's using? Just curious....- RR.
Old May 31, 2010 | 09:29 AM
antichrist's Avatar
Which clamp? All stainless hose clamps. Not sure what else you would use...
Old May 31, 2010 | 10:04 AM
Hey Tom, I understand the adjustable type ( with the screw top ) are referred to as aircraft clamps and then there are tension clamps. I lean towards aircraft clamps myself but I took my truck into the LR dealer to replace the throttle body hose? anyhow they used the tension clamps. So I got to thinking, that's all... - RR.
Old Jun 1, 2010 | 07:04 AM
antichrist's Avatar
The problem with spring clamps (what I think you mean by tension clamps) is that, depending on the style, you ideally need special pliers designed for them to use. And while I have a set of the pliers, it's just one more thing to have in my toolbox, so I always replace them with all stainless (including the screw) worm clamps.
Sabotage
May 28, 2013 05:17 PM
Hox
Jun 9, 2011 05:42 PM
bgfnbr
Feb 10, 2011 01:50 AM
Second2None
Apr 24, 2010 04:46 PM
lowridersvt
Nov 14, 2004 01:55 PM
