Sponsored by: CARiD
HID wiring
Old Apr 30, 2005 | 05:14 PM
lovatt's Avatar
3rd Gear
Default HID wiring
hi im new to this site but i am a well know regular on mkivsupra.net, i dont own a land rover (please dont flame me to much) i own a mk4 toyota supra TT
the reason i am on here is to ask for help or ideally a wiring diagram for the new shape range rover (the one with HID front lights) i am in the process of fitting the hid units to a spare set of supra headlights i have, i already have the projectors fitted and looking like factory, all i need now is to sort the wiring out, i dont need to wire up the light level adjuster i just need to find out the wire colours for the hid loom, i am using the standard range rover ballasts
all help is much appreciated
Old May 1, 2005 | 02:26 AM
05LandRover's Avatar
Default RE: HID wiring
are these the headlights that turn when you do? if so my dad's lr3 has them, i only have a freelander. i think the lr3 and range rover are basically the same headlights
Old May 1, 2005 | 08:48 AM
lovatt's Avatar
3rd Gear
i didnt know they moved when you went around bends but thinking about it there was alot of leveling motors in the lights, all i know is they are out of the latest shape range rover vouge,
to be honest i have junked all the leveling motors anyway and have linked the units to my old manual leveling system, i would imagine you would need alot more control units and sensors to get all the self leveling working
so far i have worked out YELLOW is live and BROWN is earth, only thing i really need to find out now is what the thin purple and the thin yellow wires are for in the light loom, the rest of the loom can be junked as its for the leveling system
Old May 2, 2005 | 02:03 AM
good luck with that
Old May 3, 2005 | 02:51 PM
mikemeyer0's Avatar
no hid lights don't turn when you do, thats coming out on the new jags or bmw or something like that, anyway HID=High Intensity Discharge. There the lights that are not a bright but match more the color of the sunlight, less bright but eayser to see with, any way again to wire you jus need the hid control module, if you actually have HID bulbs you will need this module, where did you get the lights from and what was included?
Old May 3, 2005 | 03:09 PM
lovatt's Avatar
3rd Gear
everything was included, ballasts, bulbs, projectors, i had 2 compleat lights, all the control boxes are inside the lights
i own a prestige bodyshop and tuning company and we had this RR in as a write off
Old May 3, 2005 | 07:58 PM
mikemeyer0's Avatar
Who makes it or do you have any info on it, here is a link might help.
http://www.visioninet.com/Technical/tech_doc-1000.pdf
get me some more info and i'll try to help.
scarlettwu
Off Topic
Mar 25, 2009 02:10 AM
Ironman472
Nov 10, 2008 09:17 PM
fanatic516
Aug 19, 2007 10:27 PM
DV57
May 26, 2007 07:52 AM
Brad S1
Nov 6, 2006 03:18 PM
