Sponsored by: CARiD
High reving 4.6
Old Nov 3, 2008 | 04:53 PM
nojeep's Avatar
8th Gear
Default High reving 4.6
Hey Forum! I have a Range Rover P38 4.6. Upon starting the engine, the rpms jump to approximately 2000 requiring meto shift out of park/neutral andinto drive.Anyone else experience this or can pointme in the right direction of a diagnosis? Thanks for any and all input.
Old Nov 4, 2008 | 10:06 AM
Default RE: High reving 4.6
What year is it, how many miles on it?
Have you checked for vacuum leaks, cleaned the t/body and the IAC??
Old Nov 7, 2008 | 08:17 PM
nojeep's Avatar
8th Gear
It 's a 1997 RR P38 4.6. By the way...what's an IAC?
Old Nov 8, 2008 | 08:45 AM
THat is your idle control unit.
Old Nov 9, 2008 | 08:16 PM
nojeep's Avatar
8th Gear
I know this is going to sound like a stupid question but here it goes...Where is the idle control unit located?
Old Nov 10, 2008 | 11:33 AM
DiscoMike2003's Avatar
If its the same engine as my 4.6 the (IAC Idle Air Control ..Valve)
Bosch unit that actuates extra air controlled seperately of the throttle body.
It has 1 inch hoses going from intake tube after air filter to the intake manifold after the throttle body.
Remove clean out carbon deposits and replace. Its probably the same as mine on 03 disco unless they didn't use bosch yet that year.
Good luck, take pictures, ask questions.
-Michael-
wick_60010
Nov 22, 2017 04:25 AM
KMSDISCO
Jan 22, 2017 03:41 PM
omarica7
Mar 11, 2014 08:12 AM
yoshibond
Jul 20, 2012 06:50 AM
