Hot start problem, code 0340 and I can't figure it out
Current situation: I've had to put my 98 Disco back into full time service, as my son is using my daily driver until his car is fixed.
The Disco will run hot (the dash gauge starts climbing) when going up a hill or when running the AC. The electric fan is working. Turning on the heater helps with this.
If I don't run the air, all is well as long as I"m moving. I just completed a highway trip of 200 miles with no problem. However, if it is allowed to idle for a while and I turn the car off, it WILL NOT START until it cools off. It turns over, just never hits.
I have a code 0340.
I have replaced:
Camshaft position sensor
Crankshaft position sensor
Fuel Temperature Sensor
I also tried insulating the crankshaft position sensor wire, as I read that can sometimes cause issues.
Nothing has worked.
What would you try next?
Thanks!
I have a code 0340.
I have replaced:
Nothing has worked.
Thanks!
I'm guessing the engine is getting so hot the crankshaft pos sensor doesn't like it. When the crankshaft position cannot be read, the camshaft pos sensor can't calculate the proper number of rotations.
Do you still have the camshaft position sensor heat cover on the sensor?
In my signature you'll find a link to a google drive with all the manuals. Look in the D1 section for "gems obd" to see the sensor monitoring logic the ECU uses. Search for "0340" in that document.
Most importantly, if the gauge on the dash is looking hot then you are in danger of cooking your head gasket. Look at your fan clutch and radiator.
Finally, if you post in the D1 section you will get more eyeballs on the issue and a bit more help.
Sean Davison
08-04-2018 08:52 PM
