Sponsored by: CARiD
How to Remove Valve Oil Seals
Old Mar 7, 2013 | 10:40 PM
fpdavis3's Avatar
Default How to Remove Valve Oil Seals
I am replacing the head gaskets on my 2003 discovery. The Valve oil seals look old. I figured I would replace them since they came with the head gasket kit. What is the best way to remove them without damaging the valve guide. Mine are stuck like crazy.
Old Mar 8, 2013 | 12:39 AM
The seals are taken with the heads to machine shop, the machine shop skims the heads, replaces seals, guides if you order it, laps valves, etc. You get back almost new heads. The process is detailed in attached shop pages. If you want to do it you'll need to borrow a valve spring compressor.
File Type: pdf
Old Mar 8, 2013 | 08:27 PM
fpdavis3's Avatar
Sorry, I should have been more descriptive. I did take the heads to a shop and they told me the valves were great. They just milled the heads. Then when I go home, I found the valve stem oil seals in the HG kit. I had a valve spring compressor, so I decided to change them myself. I got them off with quite a bit of effort.
Now the question is, how far should they go on?? I pushed them down till the bottom touched the valve guide but, it seemed like the rubber is now touching the top of the valve guide. Will this be OK?
928paul
Mar 4, 2016 05:26 AM
abran
Jan 3, 2014 11:09 AM
wheelgarage
Oct 1, 2011 03:12 PM
tailchaser0527
Apr 18, 2009 09:38 AM
mburnett
Dec 11, 2007 11:12 PM
