Huge problem with oil and coolant
Old 03-30-2019, 08:46 AM
Received 1,589 Likes on 1,305 Posts
If memory serves me you can do oil changes on these with a suction pump. I would add a quart of oil check and repeat as needed.
For the coolant we need to see the front of the motor from the top to have a shot at telling you what might be leaking.
Given you current situation though park the truck and have her drive something else until you get home or have it towed in. Is there still under warranty by chance?
Old 03-30-2019, 02:07 PM
Cwilliamson's Avatar
4wd High
Yeah it’s larked and she’s not driving it. I have done an oil change myself without getting under the vehicle as it requires you to suction it from the top. It’s definately parked until I can confirm where the leak is coming from.
Old 03-31-2019, 02:10 AM
4wd High
Oil is fine. It was just low and when it said below minimum and scared her into thinking it was out. Definitely a coolant leak somewhere. Going to the shop Monday.
landroverI
11-02-2015 07:45 PM
Rover De Land
04-05-2013 03:02 PM
Snafu / Disco Fries
08-30-2011 08:29 AM
lipadj46
07-11-2009 08:59 AM
wadematt
06-12-2008 09:30 AM
Quick Reply: Huge problem with oil and coolant
