Sponsored by: CARiD
i need help
Old May 31, 2011 | 08:03 PM
huntitall's Avatar
Default i need help
my 1998 desco trany is bad will one from a 2000 desco work
please help
Old May 31, 2011 | 08:30 PM
Depends on where you are located.
If you are in the US then no, a DII transmission will not work in a DI but the trans from any year DI will.
I am assuming you have a automatic transmission.
Old Jun 1, 2011 | 02:43 PM
huntitall's Avatar
that sucks thay seid at nape as fare as specs its the same and yes it an auto trany.
okey as fare as making sure that its the trany.
i was going a long and i had to pull a fast stop or it was going to get ugly in a herry so i pulled the ebrake next thing you know i couldint go fowerd any more only revers
Old Jun 1, 2011 | 02:59 PM
hilltoppersx's Avatar
are you sure the tranny blew? did you get under and check the driveshaft?
Old Jun 1, 2011 | 04:26 PM
Tell us what happened and why you think it blew, when was it last serviced, how is the fluid level and what is it doing wrong?
An no way will a D2 tranny fit a D1 not here or across the pond.
Old Jun 1, 2011 | 07:39 PM
True, however the DII was introduced in '98 in Europe so if he had a '98 DII then the transmission from a 2000 would work just fine.
Thats why I asked where he was located.
Old Jun 1, 2011 | 09:19 PM
huntitall's Avatar
Yeah that’s sucks that it’s not going to work. Okay so I was going downhill fast and in a stupid move I had to stop there was someone pulling right in front of me and in the end I pulled the e-brake and when he got out of the way I let it off and go to the bottom and released that I wasn’t getting power to my tires.
So I ended up trying low and everything I could to go forward and it would not move in leas I backed up the hill and get in to a higher gear so I ended up backing it up (reeves works) to my house so I can’t see how it can be anything else but the tyranny
Old Jun 1, 2011 | 09:21 PM
Well the parking brake is not meant for stopping, it is meant for parking.
You will need to look under the truck while a friend tries to move it, make sure you are not in the way of the wheels.
Which drive shaft moves?
Old Jun 1, 2011 | 11:30 PM
huntitall's Avatar
Well nether of them do in drive
Old Jun 2, 2011 | 12:13 AM
huntitall's Avatar
Okay so on top of the full story I don’t know about the tyranny fluid or sieves time it has 80,000 miles but it’s not that it’s not slipping a little it will not drive forward when it’s in drive a fare as i can till its the tcase or tryanny it gose backwerds
