Sponsored by: CARiD
iddle 80% okay but over1500 rpm cuts of like running out of petrol please help new member
Old Mar 26, 2007 | 09:57 PM
jazzmus011's Avatar
4th Gear
Default iddle 80% okay but over1500 rpm cuts of like running out of petrol please help new member
89 range rover fuel or electrical problems which i don't know but change fuel pump didin't make any good
Old Mar 26, 2007 | 10:44 PM
Bill E's Avatar
Default RE: iddle 80% okay but over1500 rpm cuts of like running out of petrol please help new member
Have you checked fuel filter, ususally located near fuel tank, on my '93 it is at the botton of right hand wheel arch.
Old Mar 27, 2007 | 12:18 PM
Good suggestion Bill
Lets see what the answer is.
Mike
Old Mar 27, 2007 | 04:37 PM
geoman's Avatar
Think I can steer you in the right direction, as a few of us here at work drive the Range Rover Classic and have almost "seen it all" on this model. Thesymptoms you describe are exactly those that happen when the alternator is failing. These vehicles are "hungry" for aconsistent output of at 13.2 volts from the alternator. Once the battery cannot supply enough current, the engine starts to misfire above idle, and typically the tachometer needle starts to flucuate, if not outright drop to zero.
And yes-- it feels like a failing fuel pump or packed up filter.
So have the charging system checked out --- including checking for loose connections on the back of the alternator.
regards,
Geoman
www.eurotekapg.com
Old Mar 27, 2007 | 04:38 PM
geoman's Avatar
Meant to say a output of "at least 13.2 volts" from the alternator
Geoman
Old Mar 28, 2007 | 03:57 AM
jazzmus011's Avatar
4th Gear
Hi Geoman
This is Chris (Jazzmus011) Thank you so much about your advice to look alternator voltige I strongly belive that's the problem soon as I find the electrical short in alternator and fixed it everything goes back to normal now I am about the have a test run and see.... thank you so much WE done it.
Chris
Old Mar 28, 2007 | 04:06 AM
jazzmus011's Avatar
4th Gear
THANK YOU SO MUCH FOREVERYBODY
CHIS (Jazzmus011)
Old Mar 28, 2007 | 04:09 AM
jazzmus011's Avatar
4th Gear
THANK YOU SO MUCH FOR EVERYBODY
CHRIS (Jazzmus011)
rodwhirity
Mar 7, 2012 07:00 PM
aarongregor
Nov 13, 2011 10:02 PM
jim1372
Aug 15, 2007 09:20 PM
Kustard
Mar 18, 2006 11:12 AM
