Sponsored by: CARiD
Injectors disco 300tdi
Old May 24, 2014 | 02:37 PM
Frank Clemo's Avatar
Default Injectors disco 300tdi
Heavy oil appearance around No 1 injector...2,3,4 all perfectly dry???? Any ideas folks
Old May 24, 2014 | 06:18 PM
tuercas viejas's Avatar
Frank
Hola
Your post is vague to make a specific answer.
The deposits you report are they fuel or oil as you suggest!
Its easy to mix up the condition without knowing more.
What prompted you to pull the injectors and have you done a compression test? You should see about 400psi on each cylinder.
Do you have excessive smoke emission when running, if so is it white grey or blue?
T/V
ZachSteve1991
Apr 27, 2022 01:12 PM
mmaesner
Aug 19, 2013 11:14 PM
disco-parts
Mar 25, 2012 01:18 PM
EVN137
Jul 8, 2007 08:21 PM
cruzen
Mar 22, 2007 06:29 PM
