Sponsored by: CARiD
Low beam issues! (Both not working)
Old Jun 18, 2014 | 09:30 PM
Disc James's Avatar
Default Low beam issues! (Both not working)
Hey guys!
So I've got an 03 d2, the low beams are not coming on, but the high beams work fine.
I've read a lot about the issue and I'm thinking it's 1 of 4 things
-the switch.
- the pink Lucas relay?
- another relay located elsewhere
- grounding issue.
I get power up to the fuse (tested with a continuity tester)
Let's talk about it!
Old Jun 20, 2014 | 02:26 AM
Disc James's Avatar
Update: I ordered a new switch, even though no one responds, I think it's helpful to keep all updated on the progress of the issue.
Old Jun 20, 2014 | 07:23 AM
acamato's Avatar
Did you check the bulbs or to see if there is power at the bulb socket?
Old Jun 25, 2014 | 09:46 PM
Disc James's Avatar
Problem solved; needed bulbs.
I feel silly lol
Rover Rog
May 26, 2019 12:33 AM
Camdisco24
Sep 2, 2015 09:09 AM
binvanna
ROAMING WITH FRIENDS
Jan 22, 2013 01:56 PM
Chrisinhouston
Feb 25, 2009 06:15 PM
LR4LIFE
Nov 6, 2007 10:23 PM
