LR3 Battery Light On and Electrical Test Normal
Hi all - I'm new to the forum and appreciate any help. I have a 2007 LR3 and the red battery warning light just starting coming on. I had the battery, starter, and alternator tested at AZone and everything tested normal. Here are the results:
* Battery Voltage (12.53V), Measured (719 CCA), and Rated (730 CCA).
* Starter Tests: Voltage (11.01V), Amps (0.0A)
* Charging System Test: 14.30V (No Load) and 14.23V (Loaded)
Hoping it's something simple but learning it usually isn't . Any thoughts or advise is greatly appreciated. Thanks
arrkerr
12-14-2005 10:06 AM
