Master Cylinder kit problem
Hello
I just got signed up, like most I presume with a problem.
I have a 97 Disco I, the brake is not that good; I though to do bleeding I front brakes bleed fine but I'm getting no fluid pressure to the rear, blew out the rear lines. I know this is the master cylinder. Open the master cylinder and found out that that the previous owner add a Texmatic Transmission Fild in the braking system.
I will try to replace the master cylinder kit my self.
Haw to remove the yellow plastic cover at first, as this is my first time to open the master cylinder for the Discovery,,,,,, ANY help would be a blessing
Thanks,
Thanks,
Landzu,
Many thanks for your prompt reply, well for sure that what I will do is to replace all that eubber in the Master Cylinder.
but what I'm afread of is haw to remove the yellow plastic cover from the M. C.
if you know, please advice haw.
Thanksagain
[IMG]local://upfiles/4610/51B1CBF127DB42D6802866E4655EDFC2.jpg[/IMG]
Thanksagain
Chrisinhouston
01-06-2015 07:00 AM
