Sponsored by: CARiD
Is it my alternator?
Old Jun 10, 2006 | 07:27 PM
Mad_lr's Avatar
Default Is it my alternator?
Got a problem...Hope someone can help... The battery light is on very dim when the engine starts up but goes out when driving or at high revs. U can hear a bit of screeching noise from engine which sounds like the drive belt slipping. But have replaced the belt and still no change.
Could it be the auto tensioner not putting enough tension on the belt? If so how do I correct it? My manual doesn't say how?
Also have noticed that when I put the indicators on, the trailer light flashes once and then goes out.
Have I got complete meltdown of the wiring sysytem?????? Is it a job that I can do or do I need the help of the garage?
Cheers
Mad_lr
Old Jun 10, 2006 | 08:21 PM
btp226's Avatar
Default RE: Is it my alternator?
I had something similar happen to my 95 Disco last year, the squealing turned out to be the rear alternator bearing. My "trailer" symbol blinks once also when using the indicators (with no trailer attached). It's done that every since I added the trailer wiring kit adapter and doesn't seem to be a problem after about three years.
If you have a voltmeter, see how much voltage is at the battery with the engine running, should be something like 14v or so with it a bit above idle speed.
Good luck,
Brian
Old Jun 10, 2006 | 11:19 PM
Bait's Avatar
Year, model, and Country please!
Old Jun 11, 2006 | 01:43 PM
Mad_lr's Avatar
Thanks Btp. I'll check that.
Forgeot to say that its a Defender 90. 300 engine. I'm in the UK.
JumPeR04
Dec 17, 2009 07:57 PM
mgabriel
Dec 11, 2008 11:53 PM
arocena409
Sep 24, 2005 06:26 PM
ibncalb
Jun 2, 2005 09:02 AM
mke137
May 9, 2005 04:52 PM
