Sponsored by: CARiD
my td5 engine wont go over 75mph
Old Apr 19, 2017 | 06:46 AM
Kade Jack Boag's Avatar
Question my td5 engine wont go over 75mph
im having a problem with my defender 90 i have just converted to a td5 engine from a 300tdi and im having trouble getting over 75mph but i do have 35 inch tires on it ive been to a garage and they carnt seem to find the problem either they have pluged the ecu in and no errors have came up please help me
Old Apr 21, 2017 | 07:46 PM
loanrangie's Avatar
Could be numerous issues, did you use a TD5 defender tank/pump ?
TD5 uses a 2 stage high pressure pump, also things like MAF and the common oil in the ECU loom can restrict performance.
Old Apr 26, 2017 | 03:50 AM
loanrangie's Avatar
Actually 75 is probably maxed out with 35's, are you using a 1.4 or 1.2 transfer case ?
Old Apr 27, 2017 | 02:11 AM
Racer X's Avatar
The TD5 and the 300tdi are two different engines, you either have one or the other.
If you do have a 300tdi, with those tires 75MPH is all you're going to get.
Old Apr 27, 2017 | 04:27 AM
loanrangie's Avatar
He said he converted from tdi to td5 so i think he knows what engine he has.
Old Apr 27, 2017 | 08:04 AM
Racer X's Avatar
I see it now, I read past a word last night.
TexasRover1
Feb 20, 2017 11:45 AM
disconic
Jun 4, 2016 02:57 AM
pgaukroger
Feb 29, 2016 05:56 AM
dirtbag
Jun 3, 2015 07:51 AM
trini defender
Defender
Dec 11, 2006 05:14 AM
