Need help asap!!!
installed a new starter yesterday - thinking that was the issue. New starter when in PERFECTLY, and it drove/started 7-10 times like it was a brand new car. Went to start it again - same symptoms as before with the old starter.
this AM got a brand new battery, put it in - nothing. this is a video of what happens when I try to start it:
Before i blow ALL my money (spoiler - already did) trying to figure out what the hell is going on - do you guys have any ideas based on the sounds it makes n start up?! this is driving my crazy! any help would be amazing. thank you.
You've got a voltage drop someplace. Probably the main cable that goes to the starter or battery terminals. Sonething loose or corroded. Clean your grounds. Make sure connections are tight. That's not a bad starter. That's not enough voltage. That's the solenoid clicking starving for power.
