Need Land Rover parts
I have a 2000 Land Rover Discovery II. I need a passanger and driver side front oxygen sensor, a valve cover gasket, and a upper intake plenum gasket and spark plugs.
I'm looking for a reputable parts supplier that will work with my Land Rover. Can someone refer to a good source please?
Thank you so much.
Dakota
Thank you so much.
Dakota
Hi and thanks for responding. I'm looking for the following:
I need a passenger and driver side front oxygen sensor, a valve cover gasket, and a upper intake plenum gasket and spark plugs.
I've read in some of the land rover forums to be careful where you buy parts because they may not be suitable for my car and that they may be "knock-off" parts.
Atlantic British, Rovah Farm, Rovers North, Rock Auto, Autohaus AZ; the list goes on.
If valve cover gasket is slightly leaking, try snugging up the 8mm 12 point bolts. Also, if you are changing it, be careful of the four mounting "washers" that keep the gasket from being crushed. They can fall out and head straight inside the engine. A dab of RTV or grease keeps them in place when you do refit of gasket.
roverintherocks
12-08-2010 10:36 AM
Gavster
03-07-2009 03:44 PM
