Sponsored by: CARiD
need a little help
Old May 7, 2007 | 03:47 AM
love2disco's Avatar
4th Gear
Default need a little help
hi im new here i did alot of lookin around to find out what i need found some and not others hoping some can help
97 disco is what im working on and hers the list of little things
1.the cruse wont work the light doesnt even come on???
2.it has a 2 button remote and it wont work even with new batterys in the remote???
3.the light in the gear selecter wont work (to light up what gear your in) is there just a light bulb???
4.i put in a new seat on pass side and now the srs light in on (on the dash)???
5.how to get the radio out cant find any to do it tryed best buy, local car radio store no one has a tool
6.last but not least its hard to start some times it will just crank but if you cycle the key a couple of times it will fire right up??? fuel temp,fuel pump,fuel filter or am i lookin in the wrong place havent tried anything yet except ran injecter cleanerin and sprayed thro body inject cleaner inintake while running
any ideas ???????????
thanks
Old May 10, 2007 | 10:38 AM
adowgiert's Avatar
Default RE: need a little help
I might be able to help with a couple of those issues
1: Check the vacuum lines for the cruise control. They tend to crack and leak all the time and will cause your cruise control to stop working. The lines are on the driver's side in the engine compartment up by the brake master cyilinder. As far as I know there is no cruise control light.
2. I have the same problem with the remotes. They probably need to be reprogrammed and I'm not sure how do do that. Also, they need to be programmed in pairs, so if you only have one you may have a problem.
3. There's a light bulb on either side of the gear selector. You'll probably have to take the console off and when you do you'll see 1 plug on either side of the selector, there's your lights.
4.Not sure about the srs thing, might want to have that looked in to.
5. I got my radio out with a very small flat head screwdriver ( like the ones used to fix glasses). Put it in and unscrew the screws in there.
6. There's a lot of other guys on this forum who would be better able to answer this one. I'm fairly new to the rover game as well.
Hope some of this helps!
EOD2135
Oct 22, 2010 03:29 PM
twoxred
Sep 23, 2010 02:24 PM
davidlafrance
May 12, 2010 09:39 PM
Rover Curious
Mar 20, 2009 04:45 PM
LPs HSE
Jun 19, 2007 09:12 PM
