No current to fuel pump ??
you can check your CKPS with an OBDII scanner, set it to live data and check the rpms, 0 rpms = bad CKPS
you may also want to jump out the inertia switch just to eliminate it as a possibility.
I also believe your pump is like the other models, it only gets power for a few seconds, if the system does not see a build up of pressure, it cuts power almost instantly. in like less than 10 seconds.
Travelor
09-24-2015 06:11 PM
JumPeR04
04-07-2011 09:52 PM
karlc
05-31-2010 06:13 PM
Danny Lee 97 Disco
04-02-2010 10:37 AM
luxury1
02-06-2009 01:14 PM
