Sponsored by: CARiD
No current to fuel pump ??
Old Oct 1, 2015 | 11:54 AM
royageor's Avatar
Default No current to fuel pump ??
I have a 2003 land rover discovery. The fuel pump is new. The maf is new. I checked the fuel pump relay fuse under hood and its ok. Still no electric to the pump. Any suggestions??
Old Oct 1, 2015 | 06:43 PM
ihscouts's Avatar
R1 is the fuel pump relay, swap it with another to check it. Check the inertia switch. Beyond that it's check connectors at fuel pump.
Old Oct 2, 2015 | 06:17 AM
royageor's Avatar
Thanks for the info. I'll check those and I was advised to check the Crank Sensor also.
Old Oct 2, 2015 | 08:01 AM
drowssap's Avatar
you can check your CKPS with an OBDII scanner, set it to live data and check the rpms, 0 rpms = bad CKPS
you may also want to jump out the inertia switch just to eliminate it as a possibility.
I also believe your pump is like the other models, it only gets power for a few seconds, if the system does not see a build up of pressure, it cuts power almost instantly. in like less than 10 seconds.
Travelor
Sep 24, 2015 06:11 PM
JumPeR04
Apr 7, 2011 09:52 PM
karlc
May 31, 2010 06:13 PM
Danny Lee 97 Disco
Apr 2, 2010 10:37 AM
luxury1
Feb 6, 2009 01:14 PM
