No power steering - AEB not avaiable, power assist not avaiable, foward alert not ava
2017 RRS Diesel 70k miles
Drove car through some water outside my home. Parked car and next day parking brake was stuck gave it some gas and it relased. Then I noticed the steering wheel was very hard to move. Then the warning lights showed up on dash
Power assist not avaiable
AEB not avaiable
Foward alert not avaiable
disconnected battery didnt help. Took car for a drive and the steering started to work and warning mssages turned off. Then a few minutes later the issues cam back. The problem would come and go for a few miles then eventually it stayed.
I checked the battery and it was holding charge, 12.4 with car off, 14.5 with car running.
I got a bunch of code please see here.
https://resources.repairsolutions.co...2024095307.pdf
Any help or advise would is greatly appreciated
Apparently, the water caused a partial grounding. When I recently installed a new battery it was only at 8 volts and I got a whole list of "not available" warnings.
Since you ran through water and got similar listings, my bet is systems were not getting full voltage due to water grounding. Check low-lying areas where water might be accumulated. Blow dry damp areas.
Thank uyou for the reply.
I checked everything and all seems dry. Had the blower and hood open over nooght when I noticed this issue. I also too all connectors off the rack and pinion, dried and cleaned. Still no functioning. I am forced to use the car without powewr steering and it is very difficult. Any other suggestions?
Thank you
Thank you
Given the list of problems, it's more likely to be a module rather than individual items.
i wouldn't want to drive it that way. I would at least get things diagnosed by a reliable independent.
