Sponsored by: CARiD
No power steering - AEB not avaiable, power assist not avaiable, foward alert not ava
Old Oct 9, 2024 | 10:36 AM
Sebas54's Avatar
7th Gear
Default No power steering - AEB not avaiable, power assist not avaiable, foward alert not ava
2017 RRS Diesel 70k miles
Drove car through some water outside my home. Parked car and next day parking brake was stuck gave it some gas and it relased. Then I noticed the steering wheel was very hard to move. Then the warning lights showed up on dash
Power assist not avaiable
AEB not avaiable
Foward alert not avaiable
disconnected battery didnt help. Took car for a drive and the steering started to work and warning mssages turned off. Then a few minutes later the issues cam back. The problem would come and go for a few miles then eventually it stayed.
I checked the battery and it was holding charge, 12.4 with car off, 14.5 with car running.
I got a bunch of code please see here.
https://resources.repairsolutions.co...2024095307.pdf
Any help or advise would is greatly appreciated
Old Oct 10, 2024 | 11:52 AM
Elzot's Avatar
Apparently, the water caused a partial grounding. When I recently installed a new battery it was only at 8 volts and I got a whole list of "not available" warnings.
Since you ran through water and got similar listings, my bet is systems were not getting full voltage due to water grounding. Check low-lying areas where water might be accumulated. Blow dry damp areas.
Old Oct 11, 2024 | 09:28 AM
Sebas54's Avatar
7th Gear
Thank uyou for the reply.
I checked everything and all seems dry. Had the blower and hood open over nooght when I noticed this issue. I also too all connectors off the rack and pinion, dried and cleaned. Still no functioning. I am forced to use the car without powewr steering and it is very difficult. Any other suggestions?
Thank you
Old Oct 11, 2024 | 09:32 AM
Elzot's Avatar
Have you tried to start it up with jumpers/charger and see if you get any warnings? I'm not expert and only going from my experience but sure seems the water and problem are related. Maybe blew some fuses?
Old Oct 11, 2024 | 09:37 AM
Sebas54's Avatar
7th Gear
i have not tied it with jumper cables, but I did put the battery on a charger to top it off. I checked some fuses but I couldnt find any that werre specific for the components I am having issues with.
Old Oct 11, 2024 | 10:00 AM
Elzot's Avatar
With all the computer integrations on these things electrical issues are hard to pin down. I imagine with the recent hurricanes there will be similar posts here. Maybe someone else has more specific information. Good luck!
Old Oct 13, 2024 | 12:56 PM
Elzot's Avatar
Given the list of problems, it's more likely to be a module rather than individual items.
Old Oct 13, 2024 | 01:00 PM
Sebas54's Avatar
7th Gear
Thnak you.
I have been driving the car (only when needed) and just muscling the steering wheel to change directioon. I have noticed now that the steerging wheel is wobbly ...Can the steering wheel (itself) break loose, leving me with no steeering?
Old Oct 13, 2024 | 01:16 PM
Elzot's Avatar
Thnak you.
just a guess, but driving with the servo motor not turning could have broken the servo motor or gear teeth which might loosen the connection.
i wouldn't want to drive it that way. I would at least get things diagnosed by a reliable independent.
GavinC
May 28, 2026 06:49 PM
chpsk8
May 16, 2025 09:53 AM
chpsk8
Mar 9, 2024 06:30 PM
Raventerp
Mar 22, 2022 09:19 AM
