Sponsored by: CARiD
View Poll Results: Could this be a Throttle position sensor
yes
100.00%
no
0%
Voters: 1. You may not vote on this poll
No Power while accelerating
Old Mar 17, 2010 | 09:33 PM
Dirt Hero's Avatar
Default No Power while accelerating
I am still kind of a newbe but, have been trying to lean all I can about rovers. I bought my 2001 SE-7 last year, I have upgraded to Goodyear Duratac and installed a 2004 Hi/Lo shifter to gain the dif lock, while fixing all the little cosmetic things I can. I have 90,000 miles. The previous owner had the tranmission changed at 70k. I think because of the front U joint blowing up, I have the greese zerks on mine!?!? All in all I love it...however right now when I Floor it the RPM's stop at .....maybe 2900 but wont shift till I let off the gas a touch. This is really noticeable at highway speeds and trying to pass. I just repaced my rear O2 sensors with no change.....I live 350mi. from any dealer and want to know if anyone here has delt with this.
Rick
Old Mar 18, 2010 | 05:55 AM
Rovin4life's Avatar
any check engine lights on?
Old Mar 21, 2010 | 11:32 PM
Dirt Hero's Avatar
No, I am suspect that it is burt out or taken out......need to check.
Old Mar 25, 2010 | 05:01 PM
Why would you replace only the rear 02 sensors, what codes did you have.
By the way, the 02's have no bearing on your shift points.
Do you know how to check the tranny fluid level, if so do it, could be low.
Send me your number before you go wasting any more money on it and I'll walk you thru what to check.
Old Oct 9, 2011 | 10:48 PM
Dirt Hero's Avatar
Default Found that one
That turned out to be bad mass air flow sensor....Completing this thed 1 yr later for posterity.
Old Apr 21, 2017 | 03:09 PM
Roger Bissell's Avatar
Mike i read all your posts I have a 2004 Land Rover Discovery with 175k and am meticulous with its maintenance . However I have a vibration now as well and was hoping to speak with you further and give you details about all the work done in the last 3 weeks .
thanks
Roger
droland@teksinc.com
Jun 18, 2011 02:50 PM
Arizona man
May 1, 2011 01:42 PM
usmc0341
Aug 18, 2008 11:43 AM
ghinesley
Aug 6, 2007 01:48 PM
