Sponsored by: CARiD
O2 sensor #1
Old Oct 14, 2013 | 11:02 AM
only1elvis's Avatar
Default O2 sensor #1
check engine light came on - front O2 sensors not working
replaced and still the issue continues. the new ones test good
what am i missing? should have saved the old ones for testing
is there a fuse?
Old Oct 18, 2013 | 09:02 AM
Steve Lister's Avatar
Do you have any oil leaking from your valve covers? This tends to drip right down onto the wire connection coming from the O2 sensor and shorts it out. I went through numerous sensor replacements until I finally replaced the gaskets on my valve covers. You may try relocating the connector plugs by removing them from the back of the engine (small clip) and tie them out of the way. That is of course if you are having the oil issue.
Old Oct 18, 2013 | 09:06 AM
Check and clean your connections with electrical contact cleaner, install some die electric grease and then replace your valve covers to stop the leak.
KlamathMatt
Apr 17, 2020 05:27 AM
jfoley1
Mar 18, 2009 06:52 PM
stupid
Nov 23, 2008 01:17 PM
jmccollister
Sep 9, 2008 08:50 PM
Morgan
Aug 14, 2007 08:15 PM
