Sponsored by: CARiD
Octane
Old Dec 29, 2005 | 06:19 PM
Hank's Avatar
Default RE: Octane
Add 4oz of Acetone to a tank of gas for better gas mileage......it really does work
Old Dec 31, 2005 | 07:28 AM
Nux's Avatar
Nux
Default RE: Octane
ORIGINAL: Hank
I agree, it does work. But almost half the seals and o-rings in our fuel systems are not compatible with acetone. So, what are you saving in the long run???
Old Jan 3, 2006 | 02:44 AM
Hank's Avatar
Default RE: Octane
ORIGINAL: Nux
ORIGINAL: Hank
I don't know....I've been doing it for 60k miles, and have only changed the fuel filtera few times....
Old Jan 3, 2006 | 02:57 AM
cterrebonne's Avatar
Default RE: Octane
i see the effects of detonation everyday at work.....also knock sensors do retard the timing the counter effect for the possibility that the fuel is igniting before the spark is being thrown like stated above but knock sensors arent the most precise instruments and if they did infact work like they should then i would probably have less work at the shop. personally i run 93 and i do not like octance boosters my 2 cents and if im correct 02 sensors are only used for adjusting fuel to air ratio at idle and slightly above it after that a programed fuel and ignition map which read other various sensors...ex iat, map, a/f , tp, ect is what takes care of the rest
Old Jan 3, 2006 | 05:25 AM
mikemeyer0's Avatar
Default RE: Octane
ORIGINAL: Nux
Higher octane fuel is a slower burning. This allows a higher compression engine to advance timing without pre-detonation, thus allowing you to utilize higher HP output. Low octane fuels burn faster, hotter, and more efficiently. A higher compression engine backs off timing thus lowering potential HP, at the same time adding more fuel to compensate as said above, knocking/pinging/pre-detonation. Mind you, the addition of the extra fuel is very minimal. Our engines don't have that high compression, I don't know why people are so crazy about high octane, besides some of the benefits of the other solvents they put in to clean injectors and higher methanol quantities to prevent freezing.
Most people that actually see a positive performance difference using high octane have bad 02 sensors throwing the ECU in closed loop (default), high injector duty cycles. 02 sensors don't work properly after 30k-50k anyway. I don't think detonation could ever cause a sleeve drop as these are made with an interference fit (at .002-.003" over), the hotter they get, the stronger they hold. Blowing a hole in a piston, now that's where you can pont fingers at detonation.
High octane fuels are a waste of money in my opinion. I'd rather dump in half a gallon of methyl hydrate per fill up to do the same thing.
I love engines way to much! [sm=burnout.gif]
ummmmm......where did I say detonation would drop a sleeve?
and yes, your post is the correct way to put it.
Old Jan 3, 2006 | 07:49 AM
Nux's Avatar
Nux
Default RE: Octane
ORIGINAL: mikemeyer0
I don't know where you said this. Ummm, did I quote you on that? [sm=noooo.gif]
Old Jan 3, 2006 | 12:11 PM
mikemeyer0's Avatar
Default RE: Octane
ORIGINAL: Nux
um, yea I just re-read your post a little slower, my bad, haha.
b c
Nov 9, 2007 03:27 PM
99discoII
Sep 23, 2007 08:10 PM
Lnghrn Disco
Jun 14, 2007 12:48 PM
newdr
Jun 13, 2007 05:53 PM
meyersd
Aug 14, 2006 12:32 PM
