oil blowing through air filter on me j19td
i hope somone can help me, i have just bought a 110 2.5td j19 engine, and on my way home, oil started pissing out of me air filter. any ideas anyone?
please help
regards fuel.............
please help
The oil is coming from your turbo, this can be due to a blocked oil return feed, or bearing failure of the turbo.
Remove the air filter pipe from your turbo and look, waggle the fins your can see, you will have a small amount of movement, (note small) but if you can move them a lot and catch the sides, then bad news.
Most likely though it is the oil return feed is blocked, (oil is feed to the turbo to allow it to be lubricated fully) this is a small pipe leaving your turbo at the front. Remove the small pipe and check for blockages.
Hope it is of help and let us know how you get on
Joseph David
Mar 14, 2011 04:04 AM
Steve B
Jun 25, 2007 08:54 AM
