i have a 91 RR county se, and its leaking i cant reallytell where is leaking, butthere is oil on the exhaust pipes coming from the engine and some on the transmission (still engine oil not trans. fluid) so is this an oil pan leak form the gasket?thanks in advance
You best go power scrub the engine instead of guessing. Degrease it, power scrub it and watch it over the next few days of driving. Most likely you have valve cover gaskets leaking, maybe a front cover seal and a pan gasket.
Mike
