Sponsored by: CARiD
oil transmission light indicator
Old 04-28-2015 | 12:44 AM
Kayode Oyenuga's Avatar
Default oil transmission light indicator
Good day guys, for sometimes now my oil transmission light always come on whenever I am held in traffic when the engine is still on and it will goes off at times when I drive on and stay on at times too. Any help will be highly appreciated, thanks in advance.
Old 04-28-2015 | 01:47 PM
justryan's Avatar
Can you post a pic of what this light looks like ?... because oil transmission light indicator sounds strange ....
Old 04-28-2015 | 07:52 PM
drowssap's Avatar
What type of vehicle is it?
a DII does have a transmission light
Old 04-30-2015 | 08:15 AM
MM3846's Avatar
The trans temp warning light?
Old 04-30-2015 | 08:23 AM
dusty1's Avatar
Old 04-30-2015 | 08:27 AM
dusty1's Avatar
if 15
that is a temp light operated from 2 senders. one is on the transfer case and the other is on the trans oil cooler (right side) sensors can go bad, but 1st thing 1st check the level of fluids.
an easy way to determine which is your trigger......next time its on, crawl under and pull the 2 leads off the tcase sender. if the light goes out, that one is yo problem
Old 04-30-2015 | 08:51 AM
drowssap's Avatar
make sure you check the level with the truck running
Old 04-30-2015 | 10:52 AM
Thanks guys, I was talking about transmission temperature warning lamp (red). I am sure the fluid level is ok as I was forced to completely replaced it when it started so it can not be the fluid. So Dusty 1, what are the two leads were you talking above and what is the tcase as well? Pictures will really help. Thanks in a million
Old 04-30-2015 | 11:10 AM
dusty1's Avatar
transfer case. the sensor is easily visible from below
Old 04-30-2015 | 11:00 PM
Once again thanks Dusty 1, I will check my oil temperature switch and oil cooler sensor but I have a feeling it is my oil temperature switch as my last scan did not say anything about oil cooler sensor but I will scan again to be very sure.
Quick Reply: oil transmission light indicator
