Sponsored by: CARiD
Over rich Zenith 36 iv
Old Sep 5, 2015 | 12:03 PM
GlennSalter's Avatar
7th Gear
Default Over rich Zenith 36 iv
I have rebuilt completely series 3 engine. Put back together and it runs. Have stripped and rebuilt carb twice, replaced main jet, secondary pump jet, set float chamber to less than 30 mil, have replaced venturi O ring seal twice, all to no avail. Zenith etc cannot answer the problem. It still runs too rich and is hunting and stutters on acceleration, plugs black up within 10 mins. Any ideas? Just to confirm it is a 2.25 petrol.
Old Sep 6, 2015 | 09:17 PM
ihscouts's Avatar
Nice link for ya; http://www.series123.com/AUShomepage...137/index.html
Best of luck with a tough carb to make work right even when new.......
Old Sep 7, 2015 | 03:22 AM
7th Gear
Default Zenith
Thank you. Yes, I had found this link and the only thing left to try is to look AGAIN at the diaphragm in the top section to see if sedimented up . But checked on previous occasions and looked all ok. if not then a gun is probably in order!
Old Sep 7, 2015 | 02:20 PM
7th Gear
Just re-stripped and cleaned out diaphragm as suggested by post . Slightly better but still too rich. have just ordered a fuel pressure regulator valve from Zenith. This apparently according to their manual can often be the problem if all else is checked and cleared.
I will let you know how I get on.
SolbergFanBoi
Mar 5, 2012 07:05 PM
dmonares
Aug 27, 2006 01:47 PM
hoberock
Jul 18, 2006 10:24 PM
Tibbs
Oct 2, 2005 12:08 AM
bboat567
Aug 2, 2005 12:19 AM
