Sponsored by: CARiD
overheating 1999 disco 2
Old Oct 20, 2005 | 04:34 PM
forbin10's Avatar
Default overheating 1999 disco 2
i have changed the thermostat, waterpump and sending unit what else is there besides the head and gasket????
Old Oct 20, 2005 | 09:00 PM
JKK's Avatar
JKK
Default RE: overheating 1999 disco 2
is your electric fan working?
Old Oct 20, 2005 | 11:42 PM
rinmud's Avatar
no electric fan guys, its a viscuos coupler maybe but i dont think so maybe radiator probably heads
Old Oct 24, 2005 | 04:07 PM
anonimaus's Avatar
are you losing fluid rapidly? If so, my vote is the head gasket. If not, then I would look at a plugged radiator or inlet.
Old Oct 24, 2005 | 06:03 PM
forbin10's Avatar
not losing the fluid to quick, just found out that the head gasket was replaced a little over a year ago and so that doesn't sound good to me poss the head is cracked, any estimates on a price of that in indiana..
Old Oct 25, 2005 | 01:24 AM
Landzu's Avatar
Have you checked the radiator for cool spots.
it may be pluged up.
The coolant gets low and then it over heats ?
Your not losing the fluid to quick, is it just getting low no leaks?
Is the oil milky? Can you smell a difference in the exhaust ?
How long does it take for it over heat?
Does it miss until it is warmed up?
I have gone through this with a truck a few years ago the (?'s) I asked will help me help you.
Mike.
Old Oct 25, 2005 | 03:25 PM
forbin10's Avatar
i don't know the answer to thse questions will look at all that tonite at work now will respond tomorrow.
thanks for all the help so far.
Old Oct 26, 2005 | 03:04 PM
forbin10's Avatar
couldn't find any cool spots on the radiator, the temp gauge stay at half for about 15-20 min. in idle park then when i drive it goes up in a matter of moments, i can't find a leak anywhere when it overheats there is always fluid in there, yes the exhaust has a different smell to it ans yes it does miss.. hope this helps.. oh and the spark plugs do not look like they have steam cleaned..
Old Oct 26, 2005 | 10:59 PM
Landzu's Avatar
The smell is burning antifreeze, not alot just a little.
Piston compression maybe pushing air into the water jacket &
pushing out antifreeze.
You need to do a compression check, you can get a gauge at Sears.
You should find a lower pressure on at least one cylinder.
This would be a head gasket. The bottom row of bolts may have
been over tightened.
If you dont find lower pressure you may have a cracked head.
Old Oct 26, 2005 | 11:06 PM
Landzu's Avatar
You can check Tect tips
They have some good info.
