Sponsored by: CARiD
P0135
Old Apr 9, 2008 | 05:25 PM
snugg's Avatar
Default RE: P0135
Thanks once again mike!
Old Apr 10, 2008 | 09:56 PM
roverguy7's Avatar
Default RE: P0135
hold on here... bank 1 sensor 1 is not the drivers side, its top sensor on the pass side. also, are you sure the first code was the heater circuit? if not, then you most likley will need a new cat on the pass side, which will be covered under your emmisions warranty. and even if it did throw first, take it into the dealership, theyll replace the cat based on the other code, and maybe the sensor too if youre lucky
[/align]
Old Apr 11, 2008 | 06:25 AM
snugg's Avatar
Default RE: P0135
ok i'm lost.I think i will try socalrover84reconmmendation and switch the two senors to see if i get an error code on the opposite side. That seems like the best option, that way i should know if it's the senor or the cat. If it's the cat, then i'll just take it in.
diftspec
Oct 14, 2014 10:59 PM
deltbro
Mar 13, 2013 12:04 PM
lyleorszulak807
Jul 21, 2010 10:10 AM
lipadj46
Jun 12, 2009 12:04 PM
Dino76
Apr 27, 2008 09:19 AM
