Sponsored by: CARiD
P1170 Trouble Code
Old Jan 24, 2009 | 02:27 PM
HSEJavaBlack's Avatar
5th Gear
Default P1170 Trouble Code
Fellow Members,
I have seen some of you more experienced members give great advice and ask great questions that seem to lead to accurate repairs, without using the shotgun method of troubleshooting.
Since purchasing the 2003 HSE Range Rover I have been under warranty and still going out of pocket (heavily) everytime the vehicle goes to the dealer. I now have 60,000 happily traveled miles and now the Service Engine Soon light is solid lite, nearly simultaneously to turning 60,000. I took the truck into my local Checker and got the code P1170-According to Checker I have an pre-failure code for the O2 sensor.
Vehicle performance including mileage is great, and unchanged.
I cannot locate this code in any of the searches I have done on this forum. Can anyone help? I would appreciate whatever this vast knowlege pool can provide.
Thanks Members!
Old Jan 26, 2009 | 08:50 PM
geatlander's Avatar
4wd High
Default RE: P1170 Trouble Code
According to fixya.com, P1170 = Front heated O2 sensor no inversion (stuck).
It means that the signal isn't increasing like it should. Most likely the O2 sensor is bad. It could also be a short or that the wires aren't plugged in all the way.
I'm unsure, but I am guessing that the vehicle has multiple O2 sensors. Check to see if they are identical parts. If they are switch the two sensors and see if your code changes.
Old Feb 7, 2009 | 12:56 AM
jasondm's Avatar
I have the same problem. My gf 04 rr hse has the same code p1170. My mechanic changed all 4 o2 sensor, intake manifold rear cover and check pcv hoses no problem. But still throwing the same code. What could be the problem?
Old Jun 8, 2010 | 09:49 AM
LANDROVER LUKE's Avatar
i know this is an old thread but the problems with the p1170 code --is ussually a hairline crack in the weld at the front of the passenger side(bank 1) converter-it spans across the top of the converter and can only be seen with a mirror--it can be fixed with simply running a bead weld acroos the top of the converter(you must drop the exhaust to gain access to it)
or
if your vehicle is still within the 8 or 80 manufacturer's emission warranty the dealer should replace it for free as per the federal gov't
Old Jun 8, 2010 | 09:52 AM
Go feed back, Thanks
Where are you located?
Old Jun 8, 2010 | 09:58 AM
i am in louisville,ky...i used to be at the dealer and have seen this many times --they had problems with this till they put the jag engines in these trucks- i think they extended the warranties for the cats but not too sure
Old Jun 8, 2010 | 09:27 PM
ibis1's Avatar
Talking Cat warranty
Land Rover North America has extended the Warranty on converters to 11 years or 120,000 miles for 2003 to 2005 Range Rovers. ibis1
Old Jan 18, 2012 | 11:47 AM
dgelfuso's Avatar
or
2003 RR HSE - Which side is Bank 1 and Bank 2. I know you said passenger side, but that depends on RH or LH drive. When sitting in the vehicle, is Bank 1 on the left or right side?
Old Mar 5, 2023 | 07:10 PM
fma01709's Avatar
Default P11070
Hello,
I am getting P11070 and I replaced the two front O2 sensors and the car has 172K. The Code also states ENGINE SHUT OFF SELONOID P11701 code. I do have a basic code reader for the LandRover.
Old Mar 5, 2023 | 09:52 PM
Harvlr's Avatar
Assuming yours is also a L322 RR, try posting in that section of the forum. If not, try posting in the appropriate section for your model.
