Sponsored by: CARiD
p1448
Old Mar 8, 2007 | 02:29 AM
97nwdisco's Avatar
Default p1448
I recently had this code come up. In reserching I found it is elc system 2 fault. ssooo what is an elc system any help would help.
Old Mar 8, 2007 | 02:33 AM
97nwdisco's Avatar
Default RE: p1448
oh buy the way it has 86,000. new plugs &wires, new k&n air and oil filters syntetic blend castroil. recenly purchased it and wanted to start off on a good start.
Old Mar 9, 2007 | 10:34 PM
wardolb's Avatar
Default RE: p1448
that is a gross leak fault. something in you evap system has a leak
Old Mar 10, 2007 | 01:48 AM
97nwdisco's Avatar
Default RE: p1448
when I bought it the cruise didnt work. I found the vacum line split. I cut of the end and put it back on. then tested cruise and it worked. I did noticed that when I moved the vacume actuator I heared a squishing noise in front of the air intake under the head light. is that normal?
jason9500
May 12, 2008 01:11 PM
jason9500
May 12, 2008 08:21 AM
cdparker
Sep 9, 2006 12:16 PM
Bugman
Apr 27, 2005 01:20 AM
Bugman
Apr 26, 2005 12:32 AM
