Paranoid !!!!!!!!!!!!
OK ....when I see drops of fluidunder the car, I freak....I am seeing coolant drips,and I check the fluids religously. The resevoir is going down about 1/2 `` every 2 weeks. Oil level is good, no wet spots around heads, no steam blowing out the exhaust. I did the valley pan gasket job a year ago and there is no leak back there. I did all the rad hoses, new water pump,thermostat,seafoam trick,that little thingy on the right side plenum/throttle body was changed. Now I have orange drips on the ground and I took the oil filler cap off and it is wet inside.I dry it out and drive it and take it off and it is wet inside again. Its cold like -24 and I hope that is normal condensation. Freakin drips [:@][:@][:@][:@] am I paranoid???????
