Sponsored by: CARiD
Paranoid !!!!!!!!!!!!
Old Nov 19, 2008 | 05:06 PM
rcpeddie's Avatar
7th Gear
Default Paranoid !!!!!!!!!!!!
OK ....when I see drops of fluidunder the car, I freak....I am seeing coolant drips,and I check the fluids religously. The resevoir is going down about 1/2 `` every 2 weeks. Oil level is good, no wet spots around heads, no steam blowing out the exhaust. I did the valley pan gasket job a year ago and there is no leak back there. I did all the rad hoses, new water pump,thermostat,seafoam trick,that little thingy on the right side plenum/throttle body was changed. Now I have orange drips on the ground and I took the oil filler cap off and it is wet inside.I dry it out and drive it and take it off and it is wet inside again. Its cold like -24 and I hope that is normal condensation. Freakin drips [:@][:@][:@][:@] am I paranoid???????
Old Nov 19, 2008 | 05:08 PM
Default RE: Paranoid !!!!!!!!!!!!
Crawl under your truck with a flash light and see what you find. Other wise fill the coolant bottle to the top, when cold and then go have a coolant pressure test run to find your leak.
Old Nov 19, 2008 | 05:14 PM
rcpeddie's Avatar
7th Gear
So thatI won t scare my local shady tree mechanic shop who have never seen a LandRover.....does the mech just hook up his gauge and see if it loses pressure?............I have never seen it done, so is that about right?
Old Nov 19, 2008 | 06:17 PM
If your mechanic doesn't know how to do a coolant pressure test, find a new mechanic.
You would probably be better off going to a radiator shop and having them test it.
Old Nov 19, 2008 | 07:25 PM
rcpeddie's Avatar
7th Gear
do you think he wil have the right thingy / adaptorto screw onto the resevoir. Is it a standard test of 8lbs pressure to hold for 2 minutes?? These guys inour town know more about combine harvesters than suv s , let alone a Landy
Old Nov 21, 2008 | 03:17 PM
DiscoSam2's Avatar
My 96 Discovery has all new gaskets etc,all redone still leaks oil,can't find it
mcwilly21
Mar 1, 2011 11:12 AM
XCELLER8
Nov 30, 2009 09:05 AM
