Premium Fuel For Discovery2
Old 07-23-2006, 01:23 PM
lostangel's Avatar
7th Gear
Default Premium Fuel For Discovery2
Hello,
I just purchased a 2003 Land Rover Dicovery 2 and love it! Do I have to run premium fuel? Can I alternate between regular and premium? What if any consequences?
Thx Rick
Old 07-23-2006, 01:45 PM
Default RE: Premium Fuel For Discovery2
You stand the chance of carboning up the engine, which on a Rover is a big No No.
I will run mid grad sometimes when can't get premimun but with mid grade, I loose 1 MPG with regular, it is even worse. Plus you will screw up your ECU's ability to give you the best performance.
For what you loose in mileage, that alone should be a good reason not to go cheap.
Mike
Old 07-23-2006, 04:40 PM
discovery 96's Avatar
8th Gear
With the Gas grade does that go for older vehicles as well. I have a 96 Disco???
Old 07-23-2006, 05:05 PM
Yes, it holds for the older Rovers also, still the same old Buick engine.
You will get less mileage and have a higher amount of carbon build up on low octane.
Mike
Old 10-15-2007, 04:43 PM
newdr's Avatar
We have 3 choices: 87,89,92, octane.
Can I use 89 all the time?
Old 10-15-2007, 04:47 PM
Landzu's Avatar
92 Octane or as high as you can get.
In the mile high city, Denver I think 89 is as is all you can get.
Old 10-15-2007, 05:45 PM
I agree, as high as you can get or pay the price down the road.
Old 10-15-2007, 08:57 PM
ajh's Avatar
ajh
ajh is offline
There is one model that's low-compression I don't remember which, that one doesn't need the premium. The high compression ones do. The Rave manual explains the differences. We can get 94 at the pump here
Old 10-16-2007, 04:04 PM
Landzu's Avatar
I thing all the Disco'sNAS are the 9.35 to one.
I would love to have to have 94.
Old 10-16-2007, 05:11 PM
ajh's Avatar
ajh
ajh is offline
I don't get why 9.35:1 needs high-octane though, bikes run a lot higher than that on regular.
If you really want to drop your compression just add a shim under your heads when you next change the gasket, you can drop it but you'll lose power of course. Opening up the combustion chamber would also work. An any-fuel disco engine would rock.
Quick Reply: Premium Fuel For Discovery2
