Sponsored by: CARiD
Range Rover Help!
Old Jul 26, 2011 | 10:17 PM
02 Jag's Avatar
7th Gear
Default Range Rover Help!
We have a 2006 range rover sc that we just had serviced. They changed the PCV valve and reprogramed the powertrain module, now the car is jerky when shifting and the transmission fault limited gear warning flashed for a second. Car drove fine before we gave it to the dealer. Any help is appreciated.
Old Jul 27, 2011 | 08:25 PM
Take it back, they screwed it up they need to fix it.
Old Aug 2, 2011 | 12:59 AM
socalrovershop's Avatar
well it can be several things . why did they replace the pcv valve? i honestly dont remember seein any pcv valve in the aj motor. also why did they program the pcm? rule of thumb at any good rover shop is that you programm both transmission and engine modules since they feed off each other for shifting strategys. the jerky feeling might be due to they system learning how you drive and the light can honestly be anything. keep us posted on what fault codes are in the modules and i will shoot my two cents. I worked for Land Rover for 7 years. till i decided to venture on my own.
roversalesutah
Jan 14, 2014 11:39 AM
j.snellgrove99
Mar 4, 2013 03:05 PM
Lincoln Tarantino
Nov 14, 2011 10:41 PM
luxury1
16
Jan 12, 2009 04:44 PM
jg2003
Jan 10, 2009 09:56 PM
