Sponsored by: CARiD
range rover hse
Old May 22, 2008 | 08:59 AM
chapman4308's Avatar
3rd Gear
Default range rover hse
my wipers dont work i checked fuses all are good what else could it be please help
Old May 22, 2008 | 09:27 AM
Default RE: range rover hse
Bad switch, relay or wiper motor. Have you checked to see if you are getting power to the motor?
Old May 22, 2008 | 10:01 AM
3rd Gear
i havent checked to see if im getting power to the motor yet but it also clatters when first start up what type of oil should i use to make that not happen
Old May 22, 2008 | 10:55 AM
3rd Gear
i have no power going to the wiper motor is there a relay if so were at and if that is good what else might it be? the switch works the rear wiper but nothing in the front
Old May 22, 2008 | 11:39 AM
Can't tell you where the relay is, should show up in your owners manual.
Old May 23, 2008 | 06:36 PM
roverguy7's Avatar
what year is the range? as to the rattle on startup, most likely going to be check valves in the heads, that make sure oil stays in your vanos unit, not bad to replace, but you need a special tool to do it. and also, thats assuming its an 03-05my car
SuperchargedV8
Oct 27, 2011 12:19 PM
AmexBlackG5
Jun 25, 2008 01:04 PM
JimMayor007
Dec 5, 2007 08:46 AM
Stickestar
Appearance & Camping Set Ups
Dec 13, 2006 03:25 AM
