Sponsored by: CARiD
Range Rover III fuel filter location?
Old May 7, 2008 | 08:31 PM
bhorwhat's Avatar
Default Range Rover III fuel filter location?
Hey folks. Can't seem to find the fuel filter on my '03 RR. Anyone know where its located.
Much appreciated.
Bob
Old May 7, 2008 | 09:10 PM
roverguy7's Avatar
Default RE: Range Rover III fuel filter location?
on the underside of each of your fuel pumps. not servicible, you have a problem or just tryin to do some maintenance?
Old May 8, 2008 | 10:33 AM
bhorwhat's Avatar
Im accustomed to replacing the filter on my Disco every 60K miles.
I wonder why its not accessible/serviceable - this is a common maintenance item.
Both Atlantic British, Rovers North and British Pacific sell them.
If I can't install it though, Im going to have to return it.
Thanks
Bob
Old May 9, 2008 | 08:57 PM
lrobin3w's Avatar
There is a serviceable fuel filter, it is located on the left underside of the vehicle, before the rear wheel. a small cover must be removed to gain access.
Old May 12, 2008 | 06:35 PM
bhorwhat's Avatar
Sure enough - its there. Surprised that both the service mgr and parts mgr at Harrisburg LR dealership didn't know that.
There's four connections - three of them have what appears to be an orangeplastic non-retractable coupling over the pipe nipples. I tried rotating them also, which didn't work.
Are these disposable, ieshould I cut them off and replace them with a small adjustable retaining clip or is there some way to get them off that Im not seeing?
Thanks
Bob
Old May 12, 2008 | 08:15 PM
lrobin3w's Avatar
As far as I know they are not disposible. Do not cutthem off!Apply pressure inwardson the colored collars and at the same time pull the conectors off. It is not easy, but can be done.
rovernoob
Jul 31, 2015 10:52 AM
tim
Jan 21, 2011 08:38 PM
landkroeger
Aug 15, 2008 07:17 AM
meineke495
Nov 29, 2007 04:48 PM
Nvd
Jul 27, 2006 10:04 AM
